missing value - Forum - iMOD
- Archive
- iMOD-GUI
- User Questions
- missing value
missing value
sophie De kock, modified 4 Years ago.
missing value
Youngling Posts: 2 Join Date: 6/26/19 Recent Posts
Hi, I have a problem when running iMOD. For all my IDF files the missing value is set to -9999. In all the output files (head, bdgfrf,...), the missing value is set to 0.3402823E+39 and thus they don't consider -9999 as a missing value... How can I change that?
Peter Vermeulen, modified 4 Years ago.
RE: missing value
Youngling Posts: 6 Join Date: 11/11/13 Recent Posts
Hi Sophie,The default NODATA value for IMODFLOW is indeed 0.3402823E+39. You can change any NODATA value in an IDF via IDF-INFO, and then select the option to change the NODATA value. Hopefully this helps for you.Regards,
Peter Vermeulen
Peter Vermeulen
RE: missing value
Thank you for the reply, no it did not work at the end I've just changed all my data value to 0.3402823E+39 and then it worked.
