RE: Compilation problem with windows 7 - Forum - Delft3D
- Compilation on Windows
- RE: Compilation problem with windows 7
Youngling Posts: 3 Join Date: 6/13/18 Recent PostsDear all,
I am a Master Student in Civil Engineering and for my research I want to do numerical simulation to check the shoreline changes with different scenarios. I want to use Delft 3D for that aim. However I have problem to download and compile the source code. After installing delft 3d, I first I ran the file "prepare_sln" and then I ran the "delft3d_open" file and I got errors.
You will find in the attached file screenshots summarizing the different steps I followed.
The software I used are:
1. Tortoise SVN
2. Microsoft Visual Studio Community 2015 (Do I have to use the community or the professional one?)
3. Intel Parallel Studio XE Cluster Edition for Windows 2018. I was thinking that it was related to the version of Intel and I downloaded again Intel Parallel Studio XE Cluster Edition 2016 update 4 but it did not work also.
4.Python version 2.7.15
It would be helpful if you can give me a way to compile the source code and then start to use delft3D.
Thank you in advance.
Regards
Padawan Posts: 97 Join Date: 1/3/11 Recent PostsHi Guy Martial,
What version of the source code did you download? The latest tagged version is preferred, currently https://svn.oss.deltares.nl/repos/delft3d/tags/7545/
Can you do the following:
Inside VisualStudio, compile again,
then open tab "Output", select the full contents, copy it
into a textfile using some text editor and attach that textfile to a
post on this forum.
Youngling Posts: 3 Join Date: 6/13/18 Recent PostsHi Adri,
Thank you for your reply.
I used the latest source code as you mentioned through https://svn.oss.deltares.nl/repos/delft3d/tags/7545/.
As I already mentioned it, I used:
1. Tortoise SVN
3. Intel Parallel Studio XE Cluster Edition 2016 update 4
4. Python version 2.7.15.
You will find in the attached text file my errors.
Regards.
You placed the source code in the path "C:\Users\Polaris\Desktop\Software\Source Code\delft3d_repository". This path contains a white space between "Source" and "Code". This revision of the software can not handle that. Please put the source code in a directory without white spaces.
This issue is solved in the trunk. We are working on a new release.
Youngling Posts: 3 Join Date: 6/13/18 Recent PostsDear Adri,
That was my mistake and I corrected it now.
Martial
