convertCoordinates Matlab - Forum - Riverlab
- convertCoordinates Matlab
Tors Kouwenhoven, modified 3 Years ago.
Keen Forecaster Posts: 3 Join Date: 3/29/22 Recent Posts
I need to convert my gps coordinates from RD New to WGS84. For this I tried to use the convertCoordinates function, because I got my coordinates in a txt file from my gps and already defined them in variables in Matlab.
My input for this was: [lon,lat]=convertCoordinates(y,x,'CS1.code',28992,'CS2.code',4326);
When I did this I received the error code:
RE: convertCoordinates Matlab
For transforming the coordinates of a file (kml, pli, pol, spl, ldb…), use the EHY tool. See here how to access the OET:
EPSG 4326 is the one of Google Earth.
EPSG 28992 is RD new.
If you already have the coordinates loaded, then use <convertCoordinates>. E.g. for converting from WGS84 to RD-New:
- https://oss.deltares.nl/web/riverlab-models/accessing-models
| 1 | EHY_convert('D:\coastline.ldb','ldb','fromEPSG',4326','toEPSG',28992) |
| 1 | np=10; |
| 2 | lat=linspace(51.986777,51.998311,np); |
| 3 | lon=linspace(4.382442,4.376618,np); |
| 4 | [x_RD,y_RD]=convertCoordinates(lon,lat,'CS1.code',4326,'CS2.code',28992); |
The function <convertCoordinates> is searching for function <odd> which is not in your paths. Have you added the paths to the OET? To do this, run function <oetsettings> at the top level of the checkout.
I did add the paths in my own matlab file, but i don't understand if this is enough. Where do i run the oetsettings function, because i dont know what the checkout means.
See the last paragraph of this page: https://oss.deltares.nl/web/riverlab-models/accessing-models
Does this help?
Does this help?
That did help thank you!
