ISG editor problems
Josh Johnson, modified 4 Years ago.
ISG editor problems
Youngling Posts: 2 Join Date: 10/17/17 Recent Posts
Dear Community,
I am currently trying to run a simulation of a field with a drainage ditch beside it, using iMOD5.2 with the Stream Flow Routing Package to handle the ditch.
My problem is that the ISG editor is not working correctly. When I try to set or change bed or water levels in the editor, it frequently doesn't save the change, or looses the whole entry entirely. As well as this, iMOD keeps crashing when I'm using the editor.  Has anyone else experienced similar problems, or know anything that might help?
Many thanks in advance,
     Josh
RE: ISG editor problems
Dear Josh,
Thank you for your Post with the question about the ISG editor. An important finding.
I'm moderator of the iMOD forum and member of the iMOD development team. My judgment is that your issue can best be handled by my colleague Peter Vermeulen (iMOD architect) so I forwarded the post to him.
Maybe he will suggest a work around, but probably this needs a fix in the next iMOD release. Our team discusses an intermediate bug fix release as well.
Frans Roelofsen
moderator iMOD website
PS Because of forum issues, please confirm that you received this reply.
Dear Frans,
Thank you for forwarding the post, I'll look forward to hearing from Peter
Many thanks,
    Josh
Hi Josh, --> Can you share your ISG files with us?
So we can use them in the debugging process. Please share them in this issue or send the files to my address:  frans.roelofsen<at>Deltares.nl
Frans
