Observation points
Caroline Schlegel, modified 4 Years ago.
Observation points
Youngling Post: 1 Join Date: 2/17/21 Recent Posts
Hello, I hava a problem with observation points. In the project manager I can activate the Package and import ipf files for each layer.
But I can not find the results or even import the calculated heads. I can not find anything on this topic in the user guide. I Use Modflow2005 forthe runs. Thans in advance for your held
RE: Observation points
Hi Caroline, your question is forwarded to my colleague. Hope to inform you soon.
Frans Roelofsen
Hi Caroline, We need some more information to reproduce your issue and see what causes your problem.
Do you start your model from the iMOD GUI or with the iMOD batch option?
If you use the batch option, please share your modelfiles with me (including the PRJ file) and we can run your model our self.
We can also arrange a video call where you share your screen so we can sit together.
Please let me know. Send an e-mail to frans.roelofsen@deltares.nl.  There is a small chance that your model did not run correctly and did not write HEAD files at all. There are 2 checks you can do yourself:
1) iMOD uses Standard Modflow to run a model. Modflow2005 writes standard echo to a *.LIST file that is saved in your model folder. Go to the end of the file and see is Modflow ran correctly.
2) iMOD creates a RUN.BAT file to actually start the Modflow model. Without iMOD you can rerun your model with this RUN.BAT file: open a DOS / CMD window and run this script. Now Modflow will start and on your screen you might get some echo that explaines more. Kind regards,
Frans
