Model wont run - errors/not orthogonal - Forum - Delft3D Flexible Mesh
- Model wont run - errors/not orthogonal
I'm new to using Delft 3d flexible mesh and am just trying to get a simple model running.
I made a grid for my area (SWgridx_net.nc) which when I went to orthogonise came up with a node highlighted in yellow and an error message (pic1).
I couldn't figure out what was wrong and tried fixing it but only thing that allowed me to orthogonise the grid that I could work out was to just delete the offending point, I then added a bed level (.xyz file) and the mesh saved from this grid and bed level (grid28617finish.nc) is shown in pic2. But when i go to run the model it comes up with an error saying not orthogonal (pic3).
What can I do to fix this and get the model to run?
Thanks,Lucy
Thanks,Lucy
RE: Model wont run - errors/not orthogonal (Answer)
Dear Lucy,
As mentioned in the User Manual, orthogonality is very important for accuracy: advised orthogonality values for your grid are around 0.01. The current threshold is 0.5, already quite high.
You could use RGFGRID to improve your grid orthogonality. You need to make the grid orthogonality satisfied before running the model.
Jing Zhao
Deltares
Jing Zhao
Deltares
Lucy Tilsley, modified 8 Years ago.
Youngling Posts: 2 Join Date: 6/28/17 Recent Posts
Ok, thanks I'll try to improve the orthogonality
Thanks
Lucy
Thanks
Lucy
Camille Grimaldi, modified 7 Years ago.
Youngling Post: 1 Join Date: 5/28/18 Recent PostsHi Jing,
I have the same error but I don't see what I need to fix as my grid's orthogonality is 0.01 everywhere (see attached). Any idea of where else that could come from?
Thanks,
Camille
Michal Kleczek, modified 7 Years ago.
