Parallel run
Daniel Serrano, modified 3 Years ago.
Parallel run
Youngling Post: 1 Join Date: 5/23/18 Recent Posts
I'm trying to make a run in parallel, and while the setup is running, I'm not sure if it's actually running in parallel or not.
I get the message "Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD..."
In addition, I did execute "smpd -install" as instructed in the standard parallel example 01
(you can take a look at the run_flow2d3d_parallel.bat screenshot I attached.
I don't know what other information should I provide to be advised on this problem, so please let me know what additional info you may need.
Thanks in advance emoticon
