Problem Running RTC - Forum - Delft3D
- 2.1.6 Other
- Problem Running RTC
Problem Running RTC
Gillang Noor Nugrahaning Gusti, modified 3 Years ago.
Problem Running RTC
Youngling Post: 1 Join Date: 3/22/16 Recent Posts
I tried to run RTC module based on the instruction on the llatest Delft3D Flow Manual (V.3.15) and test example, 09.01-flow rtc from Adri Mourits. I could run the
first step to open <config_flow2d3d.xml> but nothing happens afterward and when I pressed a key, this sentence appeared in the CMD:
"This version of RTC should be used together with SobekCF/RR or with Delft3D. Correct the settings in your RTC.DAT file."
I am not really sure what to do at this point (beside that there is no clues about how to adjust that .dat file), can anyone give me some advices to solve this problem?
Sincerely,
Gillang
Sincerely,
Gillang
