d_hydro ABORT: Cannot load component library "flow2d3d.dll" - Forum - Delft3D
- d_hydro ABORT: Cannot load component library "flow2d3d.dll"
Youngling Post: 1 Join Date: 8/31/18 Recent PostsHello All,
I have compiled the source code and I am able to run all example files successfully without any errors. When I open the GUI and solve the Flow package, it gives me an error saying: d_hydro ABORT: Cannot load component library "flow2d3d.dll"
I read on the website the following instructions:
{ The term "myDelft3D" is used for the location/directory on your machine where you have chosen to install the Delft3D setup containing the GUIs. The default value for "myDelft3D" is "c:\Program Files (x86)\Deltares\Delft3D 4.xx.xx" on Windows.
Directory "myCode/bin/" contains a subdirectory named "win64". Copy this directory "myCode/bin/win64" to "myDelft3D/win32", replacing existing files }
In my case, "myCode/bin/" does not contain a subdirectory named "win64" but the one named "x64". Also my directory "myDelft3D/" does not contain "win32" but it contains a folder "flow2d3d" which has "bin32" in it.
I am able to run all the examples successfully, so what do you think might be the problem for this error? Should I try compiling all again with a clean checkout?
Thanks in advance!
Best Regards,
Shantanu
