Vegetation input file for 3D model in FLOW - Forum - Delft3D
- River
- Vegetation input file for 3D model in FLOW
Xiaofeng Zhang, modified 12 Years ago.
Youngling Post: 1 Join Date: 5/30/12 Recent Posts
Greetings?
I am using Delft3D FLOW vegetation module DPM to run the current flow over vegetation, but the vegetation are all under rigid assumption, right? May I ask, is there any input for 'vegetation' to consider the flexibility of the vegetation, such as sea grass?
Thank you,
Xiaofeng
Thank you,
Xiaofeng
Jinghui Fan, modified 5 Years ago.
RE: Vegetation input file for 3D model in FLOW
Youngling Posts: 2 Join Date: 2/5/20 Recent Posts
Hi.
I'm using additional parameter 'Filpla' in Delft3D-Flow with polygon to add vegetation effect.
The model was running, but when i opened trih and trim file, there is only one time step shown. (should be 221 time steps)
the error script shows as follow.
*** MESSAGE No Fmtbnd record found in MDF-file, item will be skipped
*** MESSAGE No Fmtsta record found in MDF-file, item will be skipped
*** MESSAGE Executable for 32-bits platform.
*** MESSAGE Double precision computation using reals of kind 8
*** Start of User Defined Model description
- new work by smaller mesh
*** End of User Defined Model description*** MESSAGE No Fmtcco record found in MDF-file, item will be skipped
*** MESSAGE No Fmtgrd record found in MDF-file, item will be skipped
*** MESSAGE Using UNESCO density formulation by default
*** MESSAGE Momentum solver flood method is specified
*** MESSAGE DRYFLP and DPSOPT both specified in MD-file. Using DPSOPT: MAX
*** WARNING Iteration parameter is set to 2
*** Start of Directional Point Model of Vegetation input
Number of vegetations: 1
Number of areas : 1
ItPlant : 50
ClPlant : 0.80000
Vegetation number 1, type : Avicenniaceae
Area number 1, type : Avicenniaceae
polygon : belt
*** End of DPM Vegetation input
*** WARNING File will not be created - Inconsistent comm. file times
it doesn't say 'simulation finished'
Could anyone help me out? Thanks a lot.
Fan
Number of areas : 1
ItPlant : 50
ClPlant : 0.80000
polygon : belt
Fan
