.tem file from Delft3D FM - Forum - Delft3D Flexible Mesh
- 3.5 DELWAQ
- .tem file from Delft3D FM
Youngling Posts: 21 Join Date: 12/22/20 Recent PostsI am running an FM HD model with temperature (Transport only), and I am outputting the all the .hyd files to run a DELWAQ model. However there is no .tem file generated. All the other .hyd files are generated. Is this a bug? Has anyone had any luck with outputting .tem files from an FM model?
RE: .tem file from Delft3D FM
Youngling Posts: 2 Join Date: 1/21/13 Recent PostsThat is very strange if that happens. In wrwaq.F90, the writing of the tem-file is switched on/off by the same jatem that switches on/off temperature in FM HD itself. Is there a tem-file mentioned in the hyd-file? Are you sure the temperature model is switched on in FM?
Youngling Posts: 21 Join Date: 12/22/20 Recent PostsYes, the temperature model is switched on, I can view the temperature results both in the map and history output files.
I still don't know what the problem was, but an update of the version of the HD engine seems to have solved the problem
