Problem to find equilibrium under variable discharge - Forum - Riverlab
- Startpagina
- Elv
- Problem to find equilibrium under variable discharge
Mohammad Kifayath Chowdhury, 3 Jaren geleden aangepast.
Keen Forecaster Berichten: 4 Aanmelddatum: 10-9-20 Recente berichten
I have the following question-
1. I have been trying to calculate using the space marching method (initype=52) for unisize sediment single branch problem. For initype 2, the code runs smoothly but with 52 it crashes with the following set of messages-
Number of elements must not change. Use [] as one of the size inputs to automatically calculate the appropriate size for that dimension. in sediment_transport, at line 145
The parents are:
1) march_step_uni, at line 62
2) ini_equi, at line 130
3) initial_condition_construction, at line 259
4) condition_construction, at line 85
5) ELV, at line 106
6) run_ELV, at line 53
7) oh_ELV_please_run, at line 157
8) main_run_single, at line 37
I tried to follow the error code, but could not solve it. What is the problem in this case? I have attached the input file.
Thanks in advance.
Best wishes,
Kifayath
The parents are:
5) ELV, at line 106
Thanks in advance.
Best wishes,
Kifayath
Bijlagen:
Victor Chavarrias, 3 Jaren geleden aangepast.
RE: Problem to find equilibrium under variable discharge
Famous Fortune teller Berichten: 97 Aanmelddatum: 24-4-20 Recente berichten
The space marching method is something for Liselot to answer... I will reach her. The crash occurs because the size of `Mak` does not match with the number of flownodes (`dx`) and the number of effective size fractions (`nef`). There must be something murky there. Maybe you could stop in debug mode and check what are the dimensions of `Mak`.
V
V
