Delft3D FM Spatially Varied Winds - Remote process not available
Delaney Benoit, modified 3 Years ago.
Youngling Post: 1 Join Date: 2/11/22 Recent Posts
Hi there,
I recently added spatially varied winds in a .apwxwy file to my model and it has stopped running. I get the following errors when running the model on the GUI:
"Remote process not available / terminated during call Initialize"
"Remote process not available / terminated during call get_Messages"
"Initialization of FlowFM has failed."
I get the following .dia output from the filed run:
"** WARNING: MDU setting "Wrihis_temperature = 1" asks to write temperature to the output his file, but no temperature is involved due to MDU setting "Temperature = 0". So we set "Wrihis_temperature = 0"  and do not write temperature to his file.
** WARNING: MDU setting "Wrihis_salinity = 1" asks to write salinity to the output his file, but no salinity is involved due to MDU setting "Salinity = 0". So we set "Wrihis_salinity = 0" and do not write salinity to his file.
** WARNING: readMDUFile: [general] guiversion=4.3.0.0 was in file, but not used. Check possible typo.
** WARNING: readMDUFile: [physics] effectspiral=0 was in file, but not used. Check possible typo.
** WARNING: readMDUFile: [output] wrishp_enc=0 was in file, but not used. Check possible typo.
** WARNING: readMDUFile: [output] waterlevelclasses=0.0 was in file, but not used. Check possible typo.
** WARNING: readMDUFile: [output] waterdepthclasses=0.0 was in file, but not used. Check possible typo.
** INFO   : Opened file : FlowFM_obs.xyn
** INFO   : Closed file : FlowFM_obs.xyn
** INFO   : Initializing flow model geometry...
** WARNING: Could not read net cells from NetCDF file 'coarsegridorgo4.nc' (is not critical). Details follow:
** INFO   : Opened file : FlowFM.ext
** INFO   : setbedlevelfromextfile: Using bedlevel as specified in net-file.
** INFO   : Done initializing flow model geometry.
** INFO   : Finding flow nodes...
** INFO   : done in      0.01600 sec.
** INFO   : Start initializing external forcings...
** INFO   : External Forcing or Initialising 'airpressure_windx_windy' from file 'new_wind.apwxwy'."
I am extremely confused, as it appears that none of the warning messages are critical and the winds are causing the failure.  I only have winds in my model, no other forces or boundary conditions. Please help if you've had this issue! Thanks so much
Teresita de Jesús Mora Ortiz, modified 3 Years ago.
RE: Delft3D FM Spatially Varied Winds - Remote process not available
Youngling Post: 1 Join Date: 11/19/21 Recent Posts
Dear Youngling,
Did you already solve this problem? I have the same warnings and I would like to know...
Thank You
