RE: Where is the waqmerge ? - Forum - Delft3D Flexible Mesh
- RE: Where is the waqmerge ?
Dmitry Kushnir, modified 3 Years ago.
Hi there,
D-Flow FM User Manual states that:
When using multiple partitions (as described in Chapter 6), D-Flow FM will create a special
output folder per partition named <DFM_DELWAQ_mdu_name_nnnn>. Since D-Water Qual-
ity can accept results for a single partition only, you have to merge the results into one using
a tool called waqmerge.
But where can I find the waqmerge? Is it available as an openearthtools application? Or should I contact the support team in order to ask for it?
Dmitry
Dmitry
I've found waqmerge in a newer revision of the source-code (140207). But I'm having difficulties with compiling it under Windows 10. Readme file states that one would need a CMake installed in a system. Well, I seem to have all prerequisites, but the code still does not compile. Any suggestions are much appreciated.
Dmitry
Dmitry
Hello again,
I've managed to successfully compile waqmerge using a newer version of CMake (which was mentioned in the prerequisites).
However, when I try to invoke waqmerge in order to produce a merged hyd-file from 6 domains, it stops with an error code 1:
Any thoughts on this are much appreciated. A log file is attached to this message.
Dmitry
Deltares, WAQMERGE Version 1.02.01.140474, Dec 10 2021, 09:29:56
execution start : 2021/12/10 09:41:42
** INFO : Number of domains found for project 'FlowFM': 6
ug_get_meshgeom, #12, ierr=0
ERROR opening file
FM_DELWAQ_FlowFM/FlowFM.hyd
Stopped with error code : 1
ERROR opening file
Dmitry
