failed to download delft3d ( SSL handshake failed: SSL alert received) - Forum - Delft3D Flexible Mesh
- 7. Other issues
- failed to download delft3d ( SSL handshake failed: SSL alert received)
KRIS Zh, modified 8 Years ago.
Youngling Post: 1 Join Date: 12/16/13 Recent Posts
Dear Community :
i cannot download delft3d when i use "svn co https://svn.oss.deltares.nl/repos/delft3d/trunk' delft3dtrunk "
also failed when "svn list "
OS: CentOS 6.9
openssl:
I try to upgrade openssl to 1.1.0f , not work.
But it's OK when i use AWS AMI to download delft3d
Thanks for any suggestion.
| 1 | [root@ip-172-31-6-166 ~]# svn co https://svn.oss.deltares.nl/repos/delft3d/trunk/ delft3dtrunk |
| 2 | svn: OPTIONS of 'https://svn.oss.deltares.nl/repos/delft3d/trunk': SSL handshake failed: SSL alert received: Handshake failed (https://svn.oss.deltares.nl) |
| 1 | [root@ip-172-31-19-177 ~]# svn list https://svn.oss.deltares.nl/repos/delft3d/trunk |
OS: CentOS 6.9
| 1 | [root@ip-172-31-6-166 ~]# lsb_release -a |
| 2 | LSB Version: :base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch |
| 3 | Distributor ID: CentOS |
| 4 | Description: CentOS release 6.9 (Final) |
| 5 | Release: 6.9 |
| 6 | Codename: Final |
openssl:
| 1 | [root@ip-172-31-6-166 ~]# openssl version |
| 2 | OpenSSL 1.0.1e-fips 11 Feb 2013 |
| 1 | [root@ip-172-31-22-46 ~]# svn list https://svn.oss.deltares.nl/repos/delft3d/trunk |
| 2 | doc/ |
| 3 | examples/ |
| 4 | gpl-3.0.txt |
| 5 | lgpl-2.1.txt |
| 6 | src/ |
| 7 | tsvn-auto-props |
Wouter Jagers, modified 7 Years ago.
RE: failed to download delft3d ( SSL handshake failed: SSL alert received)
Youngling Post: 1 Join Date: 7/14/15 Recent Posts
I've encountered the same issue.
Upon investigating, I think this is because Deltares' newest SSL certificate is using the x509v3 Subject Alternative Name extension for svn.oss.deltares.nl. The certificate itself is issued for oss.deltares.nl, and older tools seem to only check that.
Sadly, Centos 6 does not provide a more recent version of subversion and compiling one quickly leads to dependency hell.
However, the WANdisco repository does maintain more recent versions and provides an easy way to install.
You can find instructions on https://tecadmin.net/install-subversion-1-8-on-centos-rhel ; I've tried it on a test machine and it works.
Good luck !
Good luck !
