GUI Display Problems in Windows 10
Craig Jones, modified 7 Years ago.
Youngling Posts: 2 Join Date: 11/17/14 Recent Posts
Hello All,
I have recently installed the 2017 and 2018 versions of the Delft FM GUI (latest 1.4.2.39178) on two different machines running Windows 10. Functionality is fine with existing models and running simulations. The text and selection box spacing is all "off" on both Windows 10 machines. As you will see in the attached screenshot, the expansion "+" does not show up in the left hand panel, and in using Boundary Conditions as an example, the selection boxes for "Forcing Type" and other functions cannot be seen. No amount of expansion or moving windows allows these yo be seen.
I have tried multiple resolutions and other options in Windows 10 and the outcome is always as shown in the example.
Has anyone run across this or have a solution?
Thanks in advance,
Craig
Michal Kleczek, modified 7 Years ago.
RE: GUI Display Problems in Windows 10 (Answer)
Michal,
Thanks very much for the prompt response. Unfortunately the changes didn't solve the problem on one of the computers, but I will try the other when I am able to access it again. Yes, you are correct in that they are both 4k dsplays.
In the meantime we will keep working away on the other systems where the new GUI works great.
Thanks again,
Craig
