Quickplot: View *.amu file - Forum - Delft3D Flexible Mesh
- Quickplot: View *.amu file
Dear all,
I have created an *.amu and *.amv file from a script which interpolated wind data from some stations to my model domain. I am uncertain about the convention on how D-Flow will interprete the the velocity values in the files: first value --> bottom left corner or top left corner? I am uncertain, because the lower left corner id defined as the origin of the grid.
In order to visualize the interpretation, I wanted to use Quickplot. I tried ARC/INFO Asicii Grid Files, ArcInfo Ungenerate Files and Delft3D/SOBEK Meteo files as file formats. However, for all I got (different) error messages with the attached file. For example for the Delft3D/SOBEK Meteo files:
Thank you in advance,
Julius
EDIT: I am using Quickplot version 2.60.67807 (64bit) which is delivered along with Delft3D-Suite 2021.02.
- Error while opening
- D:\MasterThesis\Grid_Develop\00_Original_Data\wind-pressure_venlag\Nov12Stormperiod_07_to_17_Nov\windxdir.amu
- as Delft3D/SOBEK Meteo Files:
- Index exceeds matrix dimensions.
- In asciiwind>value2time at line 633
- In asciiwind>Local_open_file at line 332
- In asciiwind at line 68
- In private\qp_fmem at line 591
- In private\qp_proxy at line 42
- In d3d_qp>d3d_qp_core at line 335
- In d3d_qp at line 43
Julius
RE: Quickplot: View *.amu file
Hi Julius,
There was a problem with the header of your meteo-file.
I've modified it a bit (attached), and it can be opened with the Quickplot now.
Dmitry
Dmitry
Hi Dmitry,
thank you very much for this swift support! Thanks for spotting that error. Now, it works.
Best Regards,
Julius
Best Regards,
Julius
