Delft3D stack overflow error - Forum - Delft3D
- Delft3D stack overflow error
Lee Eddington, modified 3 Years ago.
Youngling Post: 1 Join Date: 6/26/23 Recent Posts
I'm new to Delft3D and am running the Wave module and getting a stack overflow error:
+SWAN is processing output request 1
1 file(s) copied.
C:\D3D\Southern California>rem exit
>>...End of SWAN run
*** ERROR: file 'norm_end' expected to signal a correct SWAN calculation
forrtl: severe (170): Program Exception - stack overflow
Image PC Routine Line Source
swan_4072ABCDE_de 00000001401D7D87 Unknown Unknown Unknown
swan_4072ABCDE_de 00000001400D00AE SWOEXF 4403 swanout1.for
swan_4072ABCDE_de 00000001400C068C SWOUTP 383 swanout1.for
swan_4072ABCDE_de 000000014002CE1A SWMAIN 598 swanmain.for
swan_4072ABCDE_de 000000014002B764 MAIN__ 110 swanmain.for
swan_4072ABCDE_de 00000001401D4FBC Unknown Unknown Unknown
swan_4072ABCDE_de 00000001401B2AE5 Unknown Unknown Unknown
KERNEL32.DLL 00007FFD0AC47614 Unknown Unknown Unknown
ntdll.dll 00007FFD0B7226F1 Unknown Unknown Unknown
I'm running on:
Windows 10 Enterprise
Delft3D 4.03.01
Delft3D-WAVE Version 3.05.04.7545M, Sep 13 2017, 20:57:19
It appears the model runs through the wave computations okay, but crashes when it's trying to do the output:
use of rescaling in 100.00 % of wet points with maximum in spectral space = 247
accuracy OK in 99.86 % of wet grid points ( 98.00 % required)
++ trace subr: HSOBND
++ trace subr: SWOUTP
++ trace subr: SWORDC
++ trace subr: SWODDC
++ trace subr: SWOEXC
++ trace subr: EVALF
++ trace subr: SWOBSTO
++ trace subr: SWOEXD
++ trace subr: SWIPOL
++ trace subr: SWOEXA
++ trace subr: SWOINA
++ trace subr: ANGDEG
1 file(s) copied.
1 file(s) copied.
My domain is pretty large with:
Gridresolution : MXC 465 MYC 1126
: MCGRD 407901
I watched the system memory usage as it runs and it's < 15%. CPU usage is 100% during the iterations, but it drops down to ~5% when it crashes processing the output request.
I derefined the grid to:
Gridresolution : MXC 233 MYC 563
: MCGRD 102115
and it runs fine.
Any help would be greatly appreciated.
1 file(s) copied.
>>...End of SWAN run
I'm running on:
Delft3D 4.03.01
1 file(s) copied.
1 file(s) copied.
: MCGRD 407901
: MCGRD 102115
and it runs fine.
