Spatially varying roughness file not correctly generated - Forum - Delft3D
- 1. Discussion
- Spatially varying roughness file not correctly generated
Eleanor Mawson, modified 3 Years ago.
Youngling Posts: 7 Join Date: 2/22/22 Recent Posts
Hi there,
I am creating a spatially varying roughness file as part of some hydrodynamic modelling I am doing on the GBR. I followed the steps found in another thread to produce a spatially varying roughness file. However, when I generate this file and check it, inside the file are a lot of negative values. I have specified the values I wanted using the polygons and assign values under the operations tab.
Am I missing a step here as to why it keeps producing a file like this?
I have attached my file so you can see.
Kind regards
Eleanor
Kind regards
Eleanor
