Compiling Delft3d 4 suit with VS and Intel oneAPI
Mohamed Fathi, modified 3 Years ago.
Youngling Posts: 4 Join Date: 5/10/23 Recent Posts
I am trying to compile Delft3d 4 suit (structural grid). I face some issues with Visual Studio and oneapi Basekit and HPCkit.
First, I used VS 2022 and the latest available versions of oneapi, but this trial didn't work.
Then, I searched a lot for VS 2019 and oneabi 2021. I already have the offline versions:
- w_BaseKit_p_2021.2.0.2871_offline.exe
- w_HPCKit_p_2021.2.0.2901_offline.exe
I installed Visual studio version 2019. Then when I try to install oneapi basekit, the installation doesn't start, just showing the background of installations as shown in the attached image and then disappeared without continuing the installation.
Any recommendations to overcome this point.
Chloe Leach, modified 3 Years ago.
RE: Compiling Delft3d 4 suit with VS and Intel oneAPI
I have the same issue. I also tried via WSL but got stuck when executing ds-install with the error: sys/sysctl.h no such file or directory - I've seen this has been discontinued, but I don't know a workaround.
Tracking answers to your post, let me know how you get on.
I am still looking for a solution. If you figured out the problem, please share the solution with us.
Geronimo Pulido, modified 3 Years ago.
Youngling Posts: 2 Join Date: 6/5/23 Recent Posts
Same problem, can't install another version of the oneAPI and the latest doesn't work
Ok, so I manage to compile the files by using visual studio 2019 version 16.8.2, and extracting the files w_BaseKit_p_2021.2.0.2871_offline.exe and w_HPCKit_p_2021.2.0.2901_offline.exe, and then running bootstraper.exe manually. I use common WinRAR to extract the files.
Hello Geronimo,
Thanks for sharing this with me. In fact I tried this before as well as today, but it didn't work.
Could you please share your email with me so that I can contact you?
​​​​​​​Thanks again!!
