DELFT 3D FM SUITE : Error when running FLOW3D RFGRID
Mathieu Soulayrol, modified 3 Years ago.
Youngling Posts: 3 Join Date: 3/9/22 Recent Posts
Hi everybody,
When I try to open RFGRID by clicking on "grid" on a flow3D FM model on DELFT3D FM Suite, I have this error :
"An unhandled exception has occurred. Delta Shell needs to be restarted
System.ArgumentNullException: Value cannot be null.
Parameter name: path2
   at System.IO.Path.Combine(String path1, String path2)
   at DeltaShell.Plugins.FMSuite.Common.Gui.RgfGrid.RgfGridEditor.CopyFilesToDirectory(String targetDir, IEnumerable`1 sourcePaths)
   at DeltaShell.Plugins.FMSuite.Common.Gui.RgfGrid.RgfGridEditor.PrepareGridCopies(String[] grids, Boolean[] gridIsEmpty, String tempDir, CoordinateSystemType systemType, ICoordinateSystem coordinateSystem)
   at DeltaShell.Plugins.FMSuite.Common.Gui.RgfGrid.RgfGridEditor.OpenGrids(String[] grids, Boolean[] gridIsEmpty, IEnumerable`1 additionalPaths, IEnumerable`1 polygons, String polFileName, CoordinateSystemType systemType, ICoordinateSystem coordinateSystem)
   at DeltaShell.Plugins.FMSuite.Common.Gui.RgfGrid.RgfGridEditor.OpenGrid(String gridPath, Boolean gridIsEmpty, IEnumerable`1 additionalPaths, ICoordinateSystem coordinateSystem)
   at DeltaShell.Plugins.FMSuite.FlowFM.Gui.NodePresenters.FmModelTreeShortcutNodePresenter.OpenGridEditor(FmModelTreeShortcut shortcut)
   at DeltaShell.Plugins.FMSuite.Common.Gui.NodePresenters.ModelTreeShortcutNodePresenterBase`1.OnNodeDoubleClicked(Object nodeData)
   at DeltaShell.Plugins.ProjectExplorer.ProjectTreeView.TreeViewDoubleClick(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnDoubleClick(EventArgs e)
   at System.Windows.Forms.TreeView.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)"
On wave model, when I open RFGRID everything worked.
Do you know where the error come from ?
Thank for your help.
​​​​​​​Soulayrol Mathieu
RE: DELFT 3D FM SUITE : Error when running FLOW3D RFGRID
I think it must be because of this: Error retrieving FM Dll version: Could not find / load dflowfm.dll.
Error: 126 - Le module spécifié est introuvable
File: C:\Program Files\Deltares\Delft3D FM Suite 2022.04 OpenHMWQ\plugins\DeltaShell.Dimr\kernels\x64\dflowfm\bin\dflowfm.dll
I don't have this file, in kernels,\x64\ I just have dmor
quest vr, modified 3 Years ago.
Youngling Post: 1 Join Date: 3/11/23 Recent Posts
Exactly what I needed! You just saved me several hours. Thanks!
