RE: "Error in mclFreeStackTrace" Quickplot - Forum - Delft3D
- RE: "Error in mclFreeStackTrace" Quickplot
CARLOS BAUTISTA, modified 3 Years ago.
Youngling Posts: 2 Join Date: 3/29/17 Recent Posts
a few years ago someone made this query ("Error in mclFreeStackTrace" Quickplot) an answer showed the solution, now I can't see the answers from that post.
Can someone help me to solve this error, helpme THANKS!
Hi Carlos,
your problem is related to the Matlab Compiler Runtime (MCR), it is not a problem of Quickplot routines.
Did you get an error message where says:
Previously accessible file “C:\Program Files\...\startup.m” is now inaccessible.
Error:Error in mclFreeStackTrace.
If you got that message, you can try one of these options:
1) Disabling your antivirus, or
2) Running Quickplot exe file as Administrator.
3) Check the exe and ctf files are in the same folder.
Kind regards
Gabriel
Kind regards
Gabriel
Matthew Doelp, modified 3 Years ago.
Youngling Posts: 2 Join Date: 7/20/17 Recent Posts
Gabriel,
I am having the same issues with running Quickplot. I tried options 1 and 2 that you mentioned, with no luck. With option 3, I was wondering which ctf files need to be with the Quickplot exe?
I first had the issue after updating my Matlab, could that have somehow interfered? I tried uninstalling and reinstalling Delft3d 4/the MCR, with no luck.
Best
Matt
Best
Matt
zhao ziyu, modified 2 Years ago.
Youngling Post: 1 Join Date: 7/1/22 Recent Posts
Hello! Did you happen to find the answer for this? I am getting the same error and I don't know how to solve it. Thank you!
sara dubosq, modified 2 Years ago.
Youngling Post: 1 Join Date: 8/21/18 Recent Posts
Hi Everyone, Same issue here, Quickplot was working perfectly and suddenly this error message. Anyone have the solution? thanks
comp knotz, modified 2 Years ago.
Youngling Post: 1 Join Date: 2/22/23 Recent Posts
Munawir Pratama, modified 2 Years ago.
I routinely encountered this issue and this is my routine before opening the quickplot.
Open this directory "C:\Users\{User Name}\AppData\Local\Temp\{User Name}"
Then delete the folder named "mcrCacheX.Y".
After this, I can open my quickplot without the {mclFreeStackTrace} warning.
Good luck, Munawir
Good luck, Munawir
