First time in *filename* start time
Eleanor Mawson, modified 3 Years ago.
Youngling Posts: 7 Join Date: 2/22/22 Recent Posts
Can someone help me figure this out please?
​​​​​​​Configfile       : config_d_hydro.xml    D3D_HOME         : /opt/delft3d/bin/..    Working directory: /home/eem530/65936/examples/OTI_test_3
executing:/opt/delft3d/bin/../bin/d_hydro config_d_hydro.xml
--------------------------------------------------------------------------------       Deltares, FLOW2D3D Version 6.03.00.000000, Mar 15 2022, 13:24:08       libflow2d3d.so entry Flow2D3D::Run--------------------------------------------------------------------------------
Part I    - Initialisation Time Dep. Data module...                runid : OTI_test_3*** full scale free slip calculation for HLESPart II   - Creating intermediate files...             ABORT: error returned by tdatmainFlow exited abnormallyterminate called after throwing an instance of 'char const*'/opt/delft3d/bin/run_dflow2d3d.sh: line 114: 2697051 Aborted                 (core dumped) $bindir/d_hydro $configfile
Inside the bcc file
table-name          'Boundary Section : 1'contents            'uniform'location            'South01'time-function       'non-equidistant'reference-time       20230110time-unit           'minutes'interpolation       'linear'parameter           'time' unit '[min]'parameter           'Salinity             end A uniform' unit '[ppt]'parameter           'Salinity             end B uniform' unit '[ppt]'records-in-table     2        8640.00   3.10000e+01   3.10000e+01       11520.00   3.10000e+01   3.10000e+01table-name          'Boundary Section : 1'contents            'uniform'location            'South01'time-function       'non-equidistant'reference-time       20230110time-unit           'minutes'interpolation       'linear'parameter           'time' unit '[min]'parameter           'Temperature          end A uniform' unit '[C]'parameter           'Temperature          end B uniform' unit '[C]'records-in-table     2        8640.00   2.00000e+01   2.00000e+01       11520.00   2.00000e+01   2.00000e+01table-name          'Boundary Section : 1'contents            'uniform'location            'South01'time-function       'non-equidistant'reference-time       20230110time-unit           'minutes'interpolation       'linear'parameter           'time' unit '[min]'parameter           'Sediment sand        end A uniform' unit '[kg/m3]'parameter           'Sediment sand        end B uniform' unit '[kg/m3]'
Munawir Pratama, modified 3 Years ago.
RE: First time in *filename* start time
Hi Eleanor,
I looked at the bcc file. I assume the error might be due to the incorrect time value at some boundary sections.
I see some inconsistency at the time. (8640-11520) or (0-1440)
This can be edited directly in your text or in the FLOW INPUT editor.
Bcc file is sometimes very sensitive to character, this might also be the source of the issue.
Thank you - Munawir
Hi Munawir,
Thank you for your help, this now works.
Kind regards
​​​​​​​Eleanor
