RE: is tcl necessary for building delft3d 4 suite tag 65936 - Forum - Delft3D
- 2.1.1 Compiling the code
- RE: is tcl necessary for building delft3d 4 suite tag 65936
Zhiling Liao, modified 3 Years ago.
Youngling Posts: 3 Join Date: 5/31/22 Recent Posts
I built the d3d 4 suit tag 65936 but couldn't run the example 05_mormerge, the error message says the environmental variable ARCH is not set. i noticed that the README in this example says tcl needs to be installed. So is tcl also a prerequisite for building this version?
Liangyi Wang, modified 3 Years ago.
Youngling Posts: 3 Join Date: 9/27/22 Recent Posts
Hi! I got lots of errors when I am compiling. Did you successfully finished the compilition? Looking forward your early reply~
Haiwei Li, modified 2 Years ago.
Youngling Post: 1 Join Date: 6/23/22 Recent Posts
Hi! I am also using the tag 65936 in linux, and I got the same error as you when I tried to run the example 05_mormerge. But when I checked the prerequistie in my cluster, I found the tcl installed already. I guess the environment or link was not built correctly, but I don't know how to addresse this. So I was also wondering whether you had this problem solved?
Haiwei
Haiwei
