RE: Inputting .xyz file for samples not working
Charles Murman, modified 3 Years ago.
Hello!
I have a .xyz file with depths that I am trying to inport to QUICKIN as a sample so that I can export it as a .dep.  However, when I inport, QUICKIN reads every coordinate value as -999,  I tried inporting a small sample of the file, about 10 lines, and it works fine.  Is there some sort of limit on the size of a .xyz sample file that QUICKIN can handle?  If there is, is there a way to convert the .xyz directly to a .dep?  A co-worker already interpolated bathymetry data so it does not need that step.
Thank you
Hi Charles!
Can you share your *.xyz file to check it and try to find the source problem?
Regards
​​​​​​​Gabriel
