Running Quickplot outside GUI - Forum - Delft3D
- Running Quickplot outside GUI
ali shahabi, modified 4 Years ago.
Youngling Posts: 3 Join Date: 8/25/14 Recent Posts
Hi Everybody
I have done a simulation on a Linux cluster, and since the output file size is huge, I want to visualize the results in the cluster. Is there anyway to run Quickplot in Linux?
Thanks.
Thanks.
Gabriel Ruiz, modified 4 Years ago.
RE: Running Quickplot outside GUI
Hi Ali,
Quickplot is a tool of Deltares Open Earth Tools (OET). If you did not use Quickplot via GUI, you would use Matlab and load OET -> Quickplot to visualize your results. If you have luck and Matlab is installed in the cluster, so you should download OET in the cluster and load it in Matlab; call Quickplot, and that's it.
Regards
Gabriel
Regards
Gabriel
