SWAN, WAVE module error with computational grid. - Forum - Delft3D
- SWAN, WAVE module error with computational grid.
Clayton Soares, modified 4 Years ago.
Youngling Posts: 4 Join Date: 5/26/21 Recent Posts
Hi everyone am facing an issue with the wave module.
Summary of the problem:
# Delft3D 4.04.01, MSWindows
#Delft3D-FLOW GUI, Version 3.59.01.57433, Aug 16 2018
#Deltares, Delft3D-WAVE GUI, Version 4.95.00.48953, Dec 13 2016,
I have two grids one finer midres.grd (450m-100m), which I use in the flow module and one coarse inner_wave.grd (4500m-950m) which I use in the wave module (obviously they lie in the same domain)
The midres.grd ( which works well on just flow module)
and inner_wave.grd(which crashes even if run standalone), most of my settings are the default for wave module.
when run online coupled or standalone, these are the errors
Error: *** ERROR: SWAN file PRINT contains ERRORS
ERROR: *** ERROR: SWAN file PRINT contains ERRORS
Wave exited abnormally
The error in the Print file is
Print file error :
3 comp. grid points on one line
Grid angle <0 or >180 degrees
Looking at the error it seems like there is something wrong in the computational grid and I cannot figure what it could be. When I created the grid, I took notice of all relevant properties (orthogonality, aspect ratio, smoothness and resolution) and stayed within limits (therefore I suppose the flow module worked well) am starting to think am missing something small and obvious here.
What I tried, among other things:
I tried using the same grid as midres.grd in the wave module, unfortunately, it still dint work
Also tried using a coarser version of the midres.grd in the wave module.
I am attaching my grid files and .mdw file below, if anyone could help out, would be great! thank you ! and Happy new year.
The ERROR snippet
$***************************** MODEL INPUT *****************************
SET LEVEL = 0.00 NOR = 90.00 DEPMIN = 0.05 _
MAXMES = 1000 MAXERR = 2 _
GRAV = 9.81 RHO = 1025.00 INRHOG = 1 _
NAUT
MODE NONST
CGRID CURV 44 56 EXCEPT 0.0 0.0 _
CIR 36 0.05 1.00 24
Resolution in sigma-space: df/f = 0.1329
READ COOR 1. 'TMP_grid2swan01' _
4 0 1 FREE
** Heading lines **
-> x-coordinates
** Heading lines **
-> y-coordinates
INPGRID _
BOTTOM CURV 0. 0. 44 56
READINP BOTTOM 1.0 'BOTNOW' 4 0 FREE
** Error : Grid angle <0 or >180 degrees
16 6 478455.3125 6012640.0000 17 6 479977.4375 6013789.0000 17 7 0.0000 0.0000
17 6 479977.4375 6013789.0000 17 7 0.0000 0.0000 16 7 477268.8750 6014210.5000
17 7 0.0000 0.0000 16 7 477268.8750 6014210.5000 16 6 478455.3125 6012640.0000
** Error : 3 comp. grid points on one line
16 7 477268.8750 6014210.5000 17 7 0.0000 0.0000 17 8 0.0000 0.0000
17 7 0.0000 0.0000 17 8 0.0000 0.0000 16 8 476081.2500 6015796.5000
17 8 0.0000 0.0000 16 8 476081.2500 6015796.5000 16 7 477268.8750 6014210.5000
16 8 476081.2500 6015796.5000 16 7 477268.8750 6014210.5000 17 7 0.0000 0.0000
16 8 476081.2500 6015796.5000 17 8 0.0000 0.0000 17 9 0.0000 0.0000
17 8 0.0000 0.0000 17 9 0.0000 0.0000 16 9 474898.3750 6017398.5000
17 9 0.0000 0.0000 16 9 474898.3750 6017398.5000 16 8 476081.2500 6015796.5000
16 9 474898.3750 6017398.5000 16 8 476081.2500 6015796.5000 17 8 0.0000 0.0000
16 9 474898.3750 6017398.5000 17 9 0.0000 0.0000 17 10 0.0000 0.0000
17 9 0.0000 0.0000 17 10 0.0000 0.0000 16 10 473726.0000 6019016.5000
17 10 0.0000 0.0000 16 10 473726.0000 6019016.5000 16 9 474898.3750 6017398.5000
16 10 473726.0000 6019016.5000 16 9 474898.3750 6017398.5000 17 9 0.0000 0.0000
16 11 472570.0312 6020650.5000 16 10 473726.0000 6019016.5000 17 10 0.0000 0.0000
17 6 479977.4375 6013789.0000 18 6 481390.5000 6014855.0000 18 7 0.0000 0.0000
18 6 481390.5000 6014855.0000 18 7 0.0000 0.0000 17 7 0.0000 0.0000
18 7 0.0000 0.0000 17 7 0.0000 0.0000 17 6 479977.4375 6013789.0000
17 7 0.0000 0.0000 17 6 479977.4375 6013789.0000 18 6 481390.5000 6014855.0000
17 7 0.0000 0.0000 18 7 0.0000 0.0000 18 8 0.0000 0.0000
18 7 0.0000 0.0000 18 8 0.0000 0.0000 17 8 0.0000 0.0000
18 8 0.0000 0.0000 17 8 0.0000 0.0000 17 7 0.0000 0.0000
17 8 0.0000 0.0000 17 7 0.0000 0.0000 18 7 0.0000 0.0000
17 8 0.0000 0.0000 18 8 0.0000 0.0000 18 9 0.0000 0.0000
18 8 0.0000 0.0000 18 9 0.0000 0.0000 17 9 0.0000 0.0000
18 9 0.0000 0.0000 17 9 0.0000 0.0000 17 8 0.0000 0.0000
17 9 0.0000 0.0000 17 8 0.0000 0.0000 18 8 0.0000 0.0000
17 9 0.0000 0.0000 18 9 0.0000 0.0000 18 10 476727.6562 6021155.0000
** Error : 3 comp. grid points on one line...
Print file error :
The ERROR snippet
NAUT
MODE NONST
CIR 36 0.05 1.00 24
4 0 1 FREE
** Heading lines **
-> x-coordinates
** Heading lines **
-> y-coordinates
INPGRID _
grid
flow-wave coupling
computational grid
deft3d-wave
coupled with flow model
coupling wave and flow
wave
print file
.prt file
grid angle
computational points
.mdw
how to fix
flow
standalone wave
RE: SWAN, WAVE module error with computational grid.
To anyone that was looking for the answer, I solved it by simply not cutting my grids anymore for the wave module. I left the shadow region in, this eliminated the problem.
basically, I was cutting my grids using a polygon I made which represented the land boundary.
