The Problem of Artificial Flume Model
Rifqi Fauzan Iskandar, modified 4 Years ago.
Youngling Post: 1 Join Date: 8/31/20 Recent Posts
Hello Everyone, i has some problem with my model.
I'm doing a modeling of flow circulation in an artificial flume.  The flow can circulate but the results of the modeling are not in accordance with the conditions that should be. At the starting point of the flow, the discharge should be greater than the other points.
But the output of the model gives incompatible results
any suggest what should i do?
I attach a file that contains an image of the modeling result
Thank you
