Error: child killed: unknown signal
Andrew Aren Ong, modified 4 Years ago.
Youngling Post: 1 Join Date: 10/24/21 Recent Posts
Good day!
I have the GUI version 4.04.02 and downloaded and compiled source code tag 7204. I found that the folders in the bins for the source code are named differently compared to the GUI (e.g. flow2d3d vs dflow2d3d). As such, I decided to copy the files within the bins into the respective GUI-provided folders instead. Afterwards, I got the return code 126 error where a library could not be found and I realized that the shared folder had a bin folder inside it while the share folder in the GUI did not, so I dragged the files out as well, overwriting any existing files. This is when I now see the error: child killed: unknown signal.
Any help would be much appreciated!
Thank you!
