RE: Compilation error in Fedora-25: gfortran: error: unrecognized command l - Forum - Delft3D
- Compilation on Linux
- RE: Compilation error in Fedora-25: gfortran: error: unrecognized command l
Compilation error in Fedora-25: gfortran: error: unrecognized command line.
Youngling Posts: 6 Join Date: 7/27/18 Recent PostsHi, I am trying to compile delft3d in fedora-25 by following the steps of ubuntu installaions.
I ran $ ./autogen.sh
./Configure
checking for MPI_Init in -lmpichf90... no
in -lmpi... (cached) no
checking for MPI_Init in -lmpich...
(cached) no
gfortran: error: unrecognized command line option
'-showme:link'; did you mean '--force-link'?
gfortran: fatal
error: no input files
compilation terminated.
configure: creating
./config.lt
config.lt: creating libtool
checking for the
extension of Delft3D plugins... .so
checking that generated
files are newer than configure... done
configure: creating
./config.status
config.status: creating Makefile
config.status: creating engines_gpl/d_hydro/Makefile
engines_gpl/d_hydro/packages/d_hydro/Makefile
config.status: creating utils_lgpl/ods/Makefile
config.status:
creating utils_lgpl/ods/packages/Makefile
config.status:
creating utils_lgpl/ods/packages/ods/Makefile
config.status:
creating utils_lgpl/ods/packages/ods/srcf/Makefile
config.status: creating utils_lgpl/ods/packages/ods/src/Makefile
config.status: creating config.h
config.status: config.h is
unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
<<<end of configure>>>
then i ran
Make
libtool: compile: gfortran -DHAVE_CONFIG_H -I. -I../../../../..
-I../../../../../utils_lgpl/deltares_common/packages/deltares_common/src
-I/include -DWITH_DELFTONLINE -O2 -ffree-line-length-none -cpp -c
io_netcdf_version.F90 -fPIC -o .libs/io_netcdf_version.o
f951:
Warning: Nonexistent include directory ‘/include’
[-Wmissing-include-dirs]
io_netcdf_version.F90 -o io_netcdf_version.o >/dev/null
2>&1
/bin/sh ../../../../../libtool --tag=FC
--mode=compile gfortran -DHAVE_CONFIG_H -I. -I../../../../..
-o netcdf_utils.lo netcdf_utils.F90
netcdf_utils.F90 -fPIC -o .libs/netcdf_utils.o
f951: Warning: Nonexistent include directory ‘/include’
netcdf_utils.F90:33:4:
use netcdf^M
Fatal Error: Can't open
module file ‘netcdf.mod’ for reading at (1): No such file or
directory
Makefile:537: recipe for target 'netcdf_utils.lo' failed
make[5]: *** [netcdf_utils.lo] Error 1
make[5]: Leaving
directory
'/home/Elahi/delft3d_repository/src/utils_lgpl/io_netcdf/packages/io_netcdf/src'
Makefile:488: recipe for target 'install-recursive' failed
make[4]: Leaving
directory
'/home/Elahi/delft3d_repository/src/utils_lgpl/io_netcdf/packages/io_netcdf'
make[3]: Leaving
directory
'/home/Elahi/delft3d_repository/src/utils_lgpl/io_netcdf/packages'
make[2]: Leaving
directory
'/home/Elahi/delft3d_repository/src/utils_lgpl/io_netcdf'
Makefile:498: recipe for target 'install-recursive' failed
make[1]: Leaving
directory '/home/Elahi/delft3d_repository/src/utils_lgpl'
Makefile:548: recipe for target 'install-recursive' failed
make:
Please help me out. How to solve these issues?
Any help would be highly appreciated.
Wasif
Youngling Posts: 6 Join Date: 7/27/18 Recent PostsAfter following all the steps of "build_ubuntu.16.04LT.readme", above errors are solved. However, now I am getting new errors related to uuid library. uuid package is already installed, but don't know why make cannot find -luuid. Errors are given below:
../../../../../engines_gpl/part/packages/utils_f/src/.libs/libutils_f.a
../../../../../engines_gpl/part/packages/kernel_f/src/.libs/libkernel_f.a
../../../../../engines_gpl/part/packages/io_f/src/.libs/libio_f.a
../../../../../engines_gpl/part/packages/data_f/src/.libs/libdata_f.a
-lpthread -luuid -ldl -lrt -lexpat -lstdc++ -pthread -fopenmp
-Wl,-rpath -Wl,/home/Elahi/delft3d_repository/src/lib -Wl,-rpath
-Wl,/home/Elahi/Downloads/libraries/netcdf_4.4/lib -Wl,-rpath -Wl,/home/Elahi/Downloads/libraries/hdf5-1.8.13/lib
/usr/bin/ld: cannot find -luuid (* but uuid
package is there in same directory)
collect2: error: ld returned 1 exit status
Makefile:631:
recipe for target 'delwaq1' failed
make[6]: *** [delwaq1] Error
make[6]: Leaving directory
'/home/Elahi/delft3d_repository/src/engines_gpl/waq/packages/delwaq1/src'
Makefile:755: recipe for target 'install' failed
make[5]: ***
[install] Error 2
make[5]: Leaving directory
make[4]: Leaving
directory
'/home/Elahi/delft3d_repository/src/engines_gpl/waq/packages/delwaq1'
Makefile:496: recipe for target 'install-recursive' failed
make[3]: Leaving
directory
'/home/Elahi/delft3d_repository/src/engines_gpl/waq/packages'
make[2]: Leaving
directory '/home/Elahi/delft3d_repository/src/engines_gpl/waq'
Makefile:493: recipe for target 'install-recursive' failed
make[1]: Leaving
directory '/home/Elahi/delft3d_repository/src/engines_gpl'
make:
<<<end>>>>
I have attached the log files. I have been trying to compile for a long time. Now I am getting frustrated and losing hope. Any kind of help or suggestion will be highly appreciated.
Padawan Posts: 97 Join Date: 1/3/11 Recent PostsHi Wasif,
Yes, compiling on Linux can really be a pain. The good news is that once you have it compiling, the process is very stable. And you are already quite far.
The error "cannot find -luuid" is caused because the package "uuid-dev" is not installed on your machine, see the prerequisites.
Youngling Posts: 6 Join Date: 7/27/18 Recent PostsHi Adri,
Thank you for your response. I am still struggling with the same issue. uuid-dev is already installed in the same directory "/usr/bin/", . Am I missing something? should I change any directory for uuid-dev anywhere? Please help me out.
Wasif
When uuid-dev is installed in the normal way, then the library "libuuid.so.1" is located in directory "/lib64". Can you check that?
Automake should add directory "/lib64" to the search paths when looking for libraries. It's difficult to find out why that goes wrong on your system.
Can you try the following: Before compiling, execute the following command:
export LD_LIBRARY_PATH=/lib64:$LD_LIBRARY_PATH
Thanks for your qucik response. I checked the location of "libuuid.so.1" is located in "/lib64'. Before compiling, I applied your given command as "export LD_LIBRARY_PATH=/lib64:$LD_LIBRARY_PATH ".
In cofigure.log i found an error line as given below:
checking for MPI_Init... yes
checking for mpi.h... yes
checking for openmpif77... no
checking for mpif77...
mpif77
checking for mpif.h... yes
checking for
openmpif90... /home/Elahi/Downloads/libraries/mpich-3/bin/mpif90
'-showme:link'; did you mean '--force-link'? (any suggestion
regarding this please?)
configure: creating ./config.lt
config.lt: creating
libtool
checking for the extension of Delft3D plugins...
.so
checking that generated files are newer than configure...
done
configure: creating ./config.status
config.status:
creating Makefile
(lots of line without any error)
config.h
<<<end of configure.log>>>
In make.log error remains the same:
libtool: compile: /home/Elahi/Downloads/libraries/mpich-3/bin/mpif90
-I-L/home/Elahi/Downloads/libraries/netcdf_4.4/lib -lnetcdff
-DWITH_DELFTONLINE
-I/home/Elahi/Downloads/libraries/netcdf_4.4/include -O2
-ffree-line-length-none -cpp -c ec_module_version.F90 -fPIC -o
.libs/ec_module_version.o
include directory ‘-L/home/Elahi/Downloads/libraries/netcdf_4.4/lib’
[-Wmissing-include-dirs] ( it seems like generated from the error in
configure?)))
‘-L/home/Elahi/Downloads/libraries/netcdf_4.4/lib’ [-Wmissing-include-dirs]
libtool: compile:
/home/Elahi/Downloads/libraries/mpich-3/bin/mpif90 -DHAVE_CONFIG_H
-DWITH_DELFTONLINE
-ffree-line-length-none -cpp -c ec_module_version.F90 -o
ec_module_version.o >/dev/null 2>&1
ibdata_f.a -lpthread -luuid -ldl -lrt -lexpat -lstdc++ -pthread
-fopenmp -Wl,-rpath -Wl,/home/Elahi/delft3d_repository/src/lib
-Wl,-rpath -Wl,/home/Elahi/Downloads/libraries/netcdf_4.4/lib
exit status
Makefile:631: recipe for target 'delwaq1'
failed
make[6]: *** [delwaq1] Error 1
make[6]: Leaving
directory
make[5]: ***
[install] Error 2
make[4]: Leaving
directory
make[3]: Leaving
directory
make[2]: Leaving
make[1]: Leaving
make:
<<<end>>>>
Workaround: uuid is only used by WAQ. If you do not need WAQ, you can
exclude it from the compilation as follows:
Open file
".../src/engines_gpl/Makefile.am" in an editor and remove
the line " waq \ "
If you do need WAQ: I'm confused: the make.log file attached to your previous post contains the error "cannot find -luuid". But the fragment you posted now contains an error message about NetCDF. Anyway, I'll ask a WAQ-colleague to help with the uuid problem.
Padawan Posts: 28 Join Date: 1/21/13 Recent Postsuuid is used in src\engines_gpl\waq\packages\waq_utils_c\src\getuuid.c
If you can't get the compilation to find uuid, you can modifiy this file, so it will generate a fake uuid. Remove this section:
#ifdef WIN32 #include <windows.h> #else #include <uuid/uuid.h> #endif
End replace the call to generate a uuid:
#ifdef WIN32
CoCreateGuid( (GUID *)guid );
#else
uuid_generate( guid );
#endif
with this:
for (i = 0; i < 16; i++) {
guid[i] = '0';
Then remove -luuid in both these Makefile.am's
src\engines_gpl\waq\packages\delwaq2\src\Makefile.am src\engines_gpl\waq\packages\delwaq1\src\Makefile.am
I hope this will avoid the need of the uuid library
Michelle
Youngling Posts: 6 Join Date: 7/27/18 Recent PostsHi Adri and Michelle,
Thanks a lot. I have successfully finished the compilation after removing WAQ. I tried by modifying getuuid.c as per Michelle's suggestion. Still, I got some errors related to uuid. However, I will use Delft3d to study wave, wind and sediment process altogether. Hope it could be done without WAQ, right?
Thanks again.
Wasif
Yes, by combining FLOW and WAVE, you can model wave, wind and sediment processes.
