RE: Ubuntu compile - open_missing_mode error - Forum - Delft3D
- Compilation on Linux
- RE: Ubuntu compile - open_missing_mode error
Youngling Posts: 2 Join Date: 5/23/18 Recent PostsHi All,
I've been trying to compile on Ubuntu for a few days as a new user to linux. I've worked out most of the errors so far (these forums have been a great help!), but am stumped by the latest one.
I've run autogen, configure, but on make I'm receiving the following error message:
In file included from /usr/include/fcntl.h:290:0,
from oc.c:45:
In function
‘open’,
inlined from ‘open_nefis_file’ at
oc.c:1296:19:
/usr/include/x86_64-linux-gnu/bits/fcntl2.h:50:4: error: call to
‘__open_missing_mode’ declared with attribute error: open with
O_CREAT or O_TMPFILE in second argument needs 3 arguments
__open_missing_mode ();
Makefile:573: recipe for target 'oc.lo' failed
make[7]: ***
[oc.lo] Error 1
make[7]: Leaving directory '/home/seb/delft3dtrunk/src/utils_lgpl/nefis/packages/nefis/src'
I'd be really grateful for any steer on how to debug! Thanks in advance for your help.
Cheers
Seb
Padawan Posts: 97 Join Date: 1/3/11 Recent PostsHi Seb,
The gnu4.6.2.log files you attached are created by me as an example of how the output should look like. Can you redirect your output to a new file and attach them to a post in this thread?
What Gnu version are you using?
Youngling Posts: 2 Join Date: 1/11/15 Recent PostsHi Seb and Adri,
I have been trying to compile delft on Ubuntu server for a couple of days and I'm getting a similar error:
In function ‘open’,
oc.c:1296:19:
error: call to ‘__open_missing_mode’ declared with attribute error:
open with O_CREAT or O_TMPFILE in second argument needs 3
arguments
Makefile:567: recipe for target 'oc.lo'
failed
make[6]: *** [oc.lo] Error 1
make[6]: Leaving
directory
'/home/beowolf/delft3dtag/src/utils_lgpl/nefis/packages/nefis/src'
Makefile:688: recipe for target 'install' failed
make[5]: ***
[install] Error 2
make[5]: Leaving directory
Makefile:490: recipe for target 'install-recursive' failed
make[4]: Leaving
directory
'/home/beowolf/delft3dtag/src/utils_lgpl/nefis/packages/nefis'
Makefile:489: recipe for target 'install-recursive' failed
make[3]: Leaving
directory
'/home/beowolf/delft3dtag/src/utils_lgpl/nefis/packages'
Makefile:491: recipe for target 'install-recursive' failed
make[2]: Leaving
directory '/home/beowolf/delft3dtag/src/utils_lgpl/nefis'
Makefile:499: recipe for target 'install-recursive' failed
make[1]: Leaving
directory '/home/beowolf/delft3dtag/src/utils_lgpl'
Makefile:549: recipe for target 'install-recursive' failed
make:
I wonder if anybody had solved this one.
Thanks in advance.
Marcelo
Padawan Posts: 97 Join Date: 1/3/11 Recent PostsHi Marcelo,
File "fcntl2.h" should not be used when compiling "oc.c". Your post above only contains the error message. The lines in stdout just before these messages contain the compile command, with all its arguments. Does that give a clue about what goes wrong?
Directory https://svn.oss.deltares.nl/repos/delft3d/trunk/src contains
two files about compiling on Ubuntu:
build_ubuntu.16.04LT.readme
build_ubuntu1604.sh
Does the
information in there help?
Directory https://svn.oss.deltares.nl/repos/delft3d/trunk/src/logs contains the full output of autogen/configure/make. It's a little bit outdated, but might be useful for you to compare with.
If you still have compilation problems, please attach the full output of autogen/configure/make to a post on this forum.
Youngling Posts: 2 Join Date: 1/11/15 Recent PostsHi Adri,
Thanks for the answer. Sorry for the incomplete post.
I'm trying to compile the tag version 7545, and I followed the instructions on the build_ubuntu.16.04LT.readme file that you mentioned. I fact, I succeed in compiling this version on a vm with ubuntu 16.04 following these instructions, but it's not working on ubuntu server 17. I will compare the logs and see if can found the error, in the meantime, I am sending the logs that you mentioned.
Thanks for attention.
Marcelo
Youngling Posts: 4 Join Date: 11/24/11 Recent PostsHi Dri,
I am also having the same problem trying to compile the vesion 7545 and trunk versions on Linux Gentoo.
I dont know how to solve this problem yet, but the there are some significant changes in glibc-2.27 in relation to glibc-2.25 - when I last compiled version 7545 succesfully. So now glibc is calling fcntl2.h to compile oc.o, and the error is that should have 3 arguments to open_nefis_file’ at oc.c:1296:19, but there is only 2.
The only way I manage to compile Delft3D again was downgrading gcc to gcc-6.4.0 in order to downgrade glibc to glibc-2.25, but I messed my system a litle doind that.
Youngling Posts: 4 Join Date: 11/24/11 Recent PostsHi,
I am sorry, but I've been playing with the d3d code without understand whats is really going on. I knew the problem was in the line 1296 of the oc.c script, so I changed that line to the 1297 line as in the following piece of the code:
1286 /* open file with appropriate access type
1287
1288 if ( fds == -1 )
1289 {
1290 if
( acType == FILE_CREATE )
1291 {
1292
fds = FILE_OPEN( file_name, acType, FILE_MODE );
1293
1294 else
1295 {
1296 /* fds =
FILE_OPEN( file_name, acType ); */
1297 fds = FILE_OPEN( file_name, acType, FILE_MODE
1298 }
1299 }
This change worked for me to compile the trunk version, once fcntl2.h require a third argument for FILE_OPEN.
I am sorry again for change the code in that way, I hope somebody who knows what are doing may fix this part of the code in a near future.
best regards
