RE: flow2d-3d: libexpat.dll missing. VS2017 Community + Ifort 18 Windows 10 - Forum - Delft3D
- Compilation on Windows
- RE: flow2d-3d: libexpat.dll missing. VS2017 Community + Ifort 18 Windows 10
Youngling Post: 1 Join Date: 5/31/18 Recent PostsHello all,
I am trying to compile Delft3D from trunk 7545 as recommended. I am using VS2017 Community edition with Ifort 2018, on Windows 10. With the help of David Gutiérrez's excellent post in this thread: https://oss.deltares.nl/web/delft3d/home/-/message_boards/message/1439326/maximized in where he outlays all steps for this combination I have managed to compile a somewhat working version. Somewhat working as in, examples which do not use flow2d-3d work (like example 7 to 11), but those which use flow2d-3d present the following error:
Checking the bin folder of the module it indeed seems the .dll file is nowhere to be found.
Now during compilation, at the end the whole process freezes and my computer runs out of memory. This seems to be a known issue with an outdated/deprecated module being compiled which is not nessecary for the end result I understood reading on the forums. The fact that the other examples work seems that there are some things going good, but something earlier is getting messed up in the compilation it seems.
What can be potential causes, and I think more importantly, what can I do to be able to find what is going wrong here so I can hopefully be guided towards a fully instead of half working compilation? I must admit that I am not particulary experienced in compiling programmes though now I have come this far I am adament to finish it.
Further information for completeness sake:
CPU: Core i7 5820k @ 4.2 ghz
Memory: 16GB
GPU: GTX 950
Windows 10 build 1803
EDIT 26-06:
I actually just found the .dll in C:\delft3d_repository\bin\win64\shared. Yet delft3d is unable to find it for some reason. I also saw Adri mention in a thread about this .dll being missing to try debug compilation. I REbuilt the solution in debug and unfortunally nothing changed. Wave module and such works, but flow is unable to run because it cannot find the .dll for some reason.
Many thanks in advance,
Dennis
Padawan Posts: 97 Join Date: 1/3/11 Recent PostsHi Dennis,
The ad hoc workaround:
Open file
"examples\01_standard\run_flow2d3d.bat" in a text editor and
replace the line:
set PATH=%exedir%;%PATH%
by:
set PATH=%exedir%;%D3D_HOME%\%ARCH%\shared;%PATH%
An alternative is to copy the contents of subdirectory "shared" into the "flow2d3d\bin" directory.
This problem will not occur in the current trunk version, because the run scripts are changed.
