RE: Windows 10 Professional crashes when compiling
Lochlan Noble, modified 6 Years ago.
Youngling Posts: 2 Join Date: 10/8/18 Recent Posts
Using Windows 10 Professional x64 , VS2015 update 3 (Professional) and IFORT 16 (Intel Parallel Studio XE 2016).
Running into some troubles compiling that are causing the Windows stop code "DPC_WATCHDOG_VIOLATION" at various points in the build.
The compiler hasn't been throwing any errors, but the compilation seems to get stuck, freezing and then crashing the computer. I tried building each of the projects individually and found that only 'tools_gpl' is causing the problem. The last line that caused a crash was 'dio-ds-config.F90'
Any suggestions/advice appreciated!
Lochlan Noble
Gabriel Lim, modified 6 Years ago.
Hi Gabriel,
Thank you for your reply, and apologies for not attaching the build output file in my original query.
After trying a couple of tags unsuccessfully I used the trunk version which worked!
