RE: vegetation module for a partially vegetated channel
XIAOCHEN CHEN, modified 9 Years ago.
Youngling Post: 1 Join Date: 5/3/15 Recent Posts
Hi there,
I am currently trying to model a channel with vegetation with Delft3D: the vegetation width is 2/3 of the channel width. The model itself runs smoothly however the model result seems no as good as I expected. The flow velocity in the vegetated area is quite similar as the flow velocity at the open channel (non-vegetated area), and velocity difference is only 0.5 cm/s. However, from the experimental data there is larger velocity difference between the vegetated flow and open channel flow, around 10 cm/s. It seems that the vegetation do not have a 'blocking effect' to slow down the flow in the Delft3D model. Can anyone help me with this problem? I attached my vegetation input file with this post also.
By the way I also try to model the channel fully covered with vegetation, but the result is quite good and quite similar with the measurements. Thanks!
Xiaohchen
shabnam mirheidarian, modified 6 Years ago.
