RE: Delwaq problem by generating proc_def.def and proc_def.dat
Gholamreza Shiravani, modified 6 Years ago.
Padawan Posts: 28 Join Date: 6/25/16 Recent Posts
Dear Delwaq developers,
I am trying to follow the instructions on page 30 of the Open Processes Liberary (OPL) manual. I did it for both Linux as well as Windows, but none of them produced the proc_def.def and proc_def.dat after compiling (the compiled results are attached). I think this was not mentioned in manualĀ or Delwaq has a problem by producing the proc_def files. Could anyone tell me what should I do after build/compilingĀ ?
Arjen Markus, modified 6 Years ago.
Padawan Posts: 67 Join Date: 1/26/11 Recent Posts
The definition of the processes you add via the Open PLCT GUI to the set is automatically stored in the processes library files you selected. If you open those, then you should be able to see the new processes. Note that this may be the processes library files that come with the installation.
By the way: I have added the makefiles needed to make the waqpb programs on Linux - these were missing (we simply never created them for these tools). After an update of the source code you should be able to build them as part of the general build process.
