RE: error about using space varying wind and pressure in additonal paramete
Ming Zhou, modified 12 Years ago.
error about using space varying wind and pressure in additonal parameters
Youngling Post: 1 Join Date: 10/9/12 Recent Posts
In my simualtion, I provide the space varying wind and pressure using the addtional parameters in Delft3D-FLOW. When I run it, there is a problem. In the diagnosis file,it is read:
"*** WARNING File will not be created - Inconsistent comm. file times
*** ERROR Flow point outside meteo grid (x-dir) x,y,: -1.0 0.0
*** ERROR Flow exited abnormally "
Could someone help me ?
Thanks in advance!
Giovanni Gunawan Gunawan Panga, modified 7 Years ago.
Vinicius Santos Santos Pessanha, modified 6 Years ago.
Youngling Posts: 2 Join Date: 8/21/18 Recent Posts
Hello Giovanni,
I'm having the same problem. Could you share how you solved the problem?
Thank you very much.
Vinicius
MD WASIF E ELAHI, modified 5 Years ago.
Youngling Posts: 6 Join Date: 7/27/18 Recent Posts
Hello Giovanni and Vinicius,
Have you guys solved this problem? I am facing the same issue.
Thanks in advance. Kind regards.
William Bennett, modified 5 Years ago.
Youngling Post: 1 Join Date: 2/10/20 Recent Posts
Hi all,Have any of you solved this problem? Or figured out what those coordinates correspond to?I am having a similar error "Error in meteo module: Flow point outside meteo grid (x-dir) x,y,:      25.9       4.6" despite my grid extents being between 49-56 latitude and -10 - -2 longitude so I don't understand what the flow point corresponds to.
Also based on my understanding of the meteofiles they encompass those areas so I'm guessing it's something fundamental I'm doing wrong.
Vinicius Santos Santos Pessanha, modified 5 Years ago.
In my case, part of the flow grid wasn't covered by the meteo grid. It was simple to solve.
