Delwaq-Define input-Discharges - Forum - Delft3D
- DELWAQ
- Delwaq-Define input-Discharges
Padawan Posts: 28 Join Date: 6/25/16 Recent PostsHi,
I have a question about Flow rate of discharges in Define Inputs of Delwaq. We couple the hydrodynamic model (Delft-Flow) data with Delwaq. Based on the coupling definition, discharges values from hydrodynamic model are already used in Flow-model and the current velocity as well as all hydrodynamic parameters like water level, shear stresses are solved with these discharges. Now, should I Input These values again in Delwaq by Define Input in Discharges? Could you please explain me the differences between the discharges in hydrodynamic Model and Delwaq model?Is the delaq model discharges extra Flow rate or we should Input the flow model flow rates againg in Define Inputs by Discharges? Why delwaq automatically select the values of hydrodynamic model in Define Inputs?
RE: Delwaq-Define input-Discharges
Youngling Post: 1 Join Date: 4/3/20 Recent Posts<a href="http://example.com/">http://example.com/</a>
