prt, tba, and tbb files does not print results
Marjorie Turiano, modified 9 Years ago.
Youngling Posts: 2 Join Date: 1/22/16 Recent Posts
Hi!
I was trying to use TRIANA to post-process a history file I have, but the prt, tba and tbb files (attached) generated does not show results. I am also attaching the inp and obs files I made. I am sure that my TRIANA is working properly because I tried running the example in the tutorial folder and it replicated the outputs... The simulation period in the history file is 1-year physical time, interval every 10 mins. For this tidal analysis I was trying to analyze only the period between 10 days and 60 days after the reference date.
I hope anyone can help me figure out what went wrong. Thanks!
Sincerely,
Marjorie
mohamed manas manas, modified 5 Years ago.
RE: prt, tba, and tbb files does not print results
Youngling Posts: 2 Join Date: 3/3/19 Recent Posts
Could you please tell me how to give "Run ident. Delft3D-Flow computation file
"So then I tried replacing tabs with 3 blanks" I couldn't understand what this says. could you please help me
