RE: SVN checkout issues - Forum - Delft3D
- Compilation on Windows
- RE: SVN checkout issues
Nandita Singh, modified 5 Years ago.
SVN checkout issues
Youngling Posts: 3 Join Date: 5/29/19 Recent Posts
I am trying to obtain the Delft 3D FLOW source code. While trying to access the latest version of the module from SVN repository, I keep getting prompted to enter my username and password. Since I cannot browse the repository as my credentials are not being accepted for some reason, I obtained the url for downloading the tag from a webinar. I don`t even know if this is a valid version of Delft 3D FLOW. When I used it to download the source code using Tortoise SVN, it only progresses when I do enter the credentials multiple times, else it stagnates. Even after this, the process ends with multiple error messages as shown in the attached screen grab.It would be really helpful, if somebody has any insight in this matter.
Gabriel Lim, modified 5 Years ago.
Hello Gabriel,
Thank you so much for your help, but I still cannot access the source code. I have to enter my credentials multiple times, only to get an authentication error. I can login to the Deltares site with these same credentials, but I simply do not know what is the problem with the SVN site.
Thank you once again. Please let me know if there is any alternative way to obtain the code. Also, if you could guide me on one more thing. I used Delft 3D Dashboard to create the input files and run a basic storm surge model. Is it a possibility that since I don`t have the Delft 3D FLOW compiled on my system, the model will not be generated in Dashboard as well? I have just started out on modelling, so I don`t know exactly what the issue is.
Regards
Nandita
Regards
Nandita
Thank you once again Gabriel.
I already have the credentials required for the SVN login. If I am not mistaken, its the same I use to log into the Deltares site. It still stops at 65kB. I have mailed the Deltares team and awaiting their reply. Regards,Nandita
Kate Lauren Neigel, modified 5 Years ago.
Youngling Post: 1 Join Date: 8/23/17 Recent Posts
Hi Nandita, did they resolve your problem? I am having the same issue. Thanks!
Felipe Calleja Apéstegui, modified 5 Years ago.
Youngling Posts: 2 Join Date: 8/20/18 Recent Posts
Hi everyone, I'm having the same problem. It does not recognize the credentials and it does not allow to access the svn.oss.deltares site. Does anyone knows what's happening?
Thanks
Thanks
Samuel Devadoss Raja Thilagar, modified 5 Years ago.
Youngling Post: 1 Join Date: 2/3/16 Recent Posts
I too have the same problem. anyone found the solutions plz share
Kenji Kumada, modified 5 Years ago.
Youngling Posts: 2 Join Date: 11/12/14 Recent Posts
I also have the same problem. If someone has the solution or the place I can contact to, please share.
