How to of the month (6) – View the data base - Delft-FEWS
23 June 2023
Did you know that with the Database Viewer, also known as Time Series Lister, it is possible to verify and inspect time series which are written to the database in any workflow?
The display is a “must use” for all configurators, because it is always necessary to check if data is stored correctly. Furthermore, it is useful to optimize the database size versus value resolutions, reducing data storage and using temporary timeseries. It also supports in checking for configuration mistakes like using external historical/forecast timeseries in a forecast workflow etc.
More information about the Database Viewer / Time Series Lister and how to use it is described on this Wiki page.
