Running suggested example results in: symbol lookup error undefined symbol - Forum - Delft3D Flexible Mesh
- 2.1.1 Compiling the code
- Running suggested example results in: symbol lookup error undefined symbol
Ronald Van Nooyen, modified 3 Years ago.
Youngling Posts: 4 Join Date: 11/17/22 Recent Posts
On linux after compile. When trying to run the suggested example <myCode>/examples/12_dflowfm/test_data/e100_f02_c02-FriesianInlet_schematic_FM the error message symbol lookup error: <myCode>/build_all/lnx64/bin/../bin/dimr: undefined symbol: __libm_feature_flag_x pops up. Does anyone know what is going on here?
From file size alone it is clear that libimf.so in lnx64/lib is not copied from one of the files in the tree under /opt/intel/oneapi. Could that be the cause?
Found the probable cause: I am compiling netcdf with the intel compilers. Reason: the gnu compiler suite version used in versions 8 or 9 of Redhat clones to build epel packages is not one of those for which the intel compiler suite recognizes the netcdf module file. Going back to the tests for netcdf-c I spotted a failure with the same symbol problem. While researching this I found a website stating that hdf5 needs to be compiled with the same compiler as netcdf. Doing so resolved this particular problem.
