Notes on install delft3fm (tag version 141346) on windows laptop
Zhiling Liao, modified 3 Years ago.
Youngling Posts: 3 Join Date: 5/31/22 Recent Posts
Hi everyone,
i figured out how to build from source code to install delft3fm on my windows laptop and just want to share my notes of the key steps and how to fix bugs. See the attached .html file. in order to open the .html normally, put the materials (.png and .css) into a folder with the same name of the .html file.
Hope it helps.
Zhiling
KIM YOUNG WOO, modified 3 Years ago.
RE: Notes on install delft3fm (tag version 141346) on windows laptop
Youngling Post: 1 Join Date: 11/9/21 Recent Posts
Thanks for your explanation.
in my case, i used intel oneapi 2023(other is same).
I followed your method exactly but got an error(please check under cc3.png  file)
(also alot of warnings)
i guess that intel oneapi 2023 is something different from 2021.
do you have any idea about solveing this ploblem.
Hi youngling,
thanks for asking, I just updated my notes and I hope this new version is more clear and useful to you.
I have not seen the error you met before so sorry I don't know what might be the cause. I would suggest to start with a clean system and install everything step by step, make sure you install all components needed when installing visual studio, I think this is where things normally go wrong cause some components might be missed.
since you are using oneapi 2023, I would suggest to pay more attention to the part about oneapi 2022 in my notes and take necessary actions when you install with oneapi 2023.
hope it goes well with your installation.
Zhiling
