How to run a parallel computing on Delft 3D windows 10
Helwis Liufandy, modified 4 Years ago.
Youngling Post: 1 Join Date: 11/20/19 Recent Posts
This is for my project. I would like to run a simulation, which is coupled between flow and wave in Delft 3D. Because of my large Simulation Area and i have  8 cores of cpu. I would like to running the flow calculation in parallel. I wanna try to use dd Flow simulation. Could you help me to give me hint to use it?
Glen Daivd Reeve, modified 4 Years ago.
RE: How to run a parallel computing on Delft 3D windows 10
Youngling Post: 1 Join Date: 8/15/17 Recent Posts
For windows you need to execute a parallel Delft3D Fm simulation using dimr. If you look in your delft install under plugins/deltasShell.Dimr/kernels/x64/dimr/scripts . There should be an example dimr_config_example.xml and run_dimr_parallel.bat.
