Specify number of threads in OpenMP D3DFM sim (Windows) - Forum - Delft3D Flexible Mesh
- Specify number of threads in OpenMP D3DFM sim (Windows)
Ben Williams, modified 9 Years ago.
Youngling Posts: 5 Join Date: 3/23/11 Recent Posts
How does one control the number of threads used by Delft3D-FM when running on Windows using OpenMP?
The manual suggests that the command line interface is used [dflowfm-cli.exe] but it seems this does not ship with D3D-FM 1.2.2.36603
How does one obtain the command line interface? Or is there another way to control the OMP threads on a Windows simulation?
Ben
Ben
Jing Zhao, modified 9 Years ago.
RE: Specify number of threads in OpenMP D3DFM sim (Windows) (Answer)
Dear Ben,
Indeed, dflowfm-cli.exe is not shipped in D3D-FM 1.2.2.36603. It will be shipped in 2018 release of D3D-FM, which would be at the end of this year.
Jing Zhao
Deltares
Jing Zhao
Deltares
Thanks Jing,
Is there a way to control the number of OMP threads in D3D-FM executed in Windows from the GUI?
Ben
Ben
Dear Ben,
As you known, we have processed your question by email conversation.
Jing Zhao
Deltares
Jing Zhao
Deltares
peng yao, modified 8 Years ago.
Youngling Posts: 6 Join Date: 4/3/11 Recent Posts
Hi Ben and Jing,
I met the same problem.
The DelftShell can not set number of OMP threads. And I also told by support department of Deltares that there are no cli-package for DflowFM2017.
May I know how did you solved it finally ?
Thanks
Peng
Thanks
Peng
Dear Peng,
We have processed your question by email conversation.
Jing Zhao
Deltares
Jing Zhao
Deltares
Youngling Posts: 6 Join Date: 4/3/11 Recent PostsBen Williams:
Thanks Jing,
Ben
Ben
Hi Ben and Jing,
Do you finally solved it? May I know how?
Thanks
Peng
