OpenEarthTools in Matlab v. 2017 - Forum - Delft3D Flexible Mesh
- 5. Pre & Post processing
- 2. OpenEarth tools
- OpenEarthTools in Matlab v. 2017
Karoline Wischnewski, modified 8 Years ago.
Youngling Posts: 4 Join Date: 12/1/16 Recent Posts
Hello everyone,
I am trying to use the OpenEarthTools with the newest Matlab version (R2017a). I downloaded the complete set of files in the /trunk/matlab directory from the deltares server. Trying to acces data within Delft FLow FM outputfiles I get confronted with the following issue:
1) launching via the MATLAB command line with oetsettings and trying to import a map.nc file with the command (I followed the procedure of the video https://www.youtube.com/watch?v=i6xiF39xn8M)
ncfile = 'map.nc';
map=dflowfm.readMap(ncfile)
returns the error
Field assignment to a non-structure array object.
Error in dflowfm.readNetOld (line 132)
G.edge.FlowLinkType.flag_values = nc_attget(ncfile, 'FlowLinkType','flag_values');
Error in dflowfm.readNet (line 128)
G = dflowfm.readNetOld(ncfile);
Error in dflowfm.readMap (line 68)
G = dflowfm.readNet(ncfile);
I also tried doing the same as before but with a history-file, which resulted in a different error
Error using netcdflib
The NetCDF library encountered an error during execution of 'inqVarID' function - 'Variable not found (NC_ENOTVAR)'.
Error in netcdf.inqVarID (line 21)
varid = netcdflib('inqVarID', ncid, varname);
Error in nc_varget_tmw>varget (line 62)
varid=netcdf.inqVarID(gid,varname);
Error in nc_varget_tmw>varget_nc (line 24)
[data,info] = varget(ncid,varname,varargin{:});
Error in nc_varget_tmw (line 5)
[data,info] = varget_nc(ncfile,varname,varargin{:});
Error in nc_vargetr (line 38)
[data,info] = nc_varget_tmw(ncfile,varname,varargin{:});
Error in nc_varget (line 35)
[data,info] = nc_vargetr(ncfile,varname,varargin{:});
Error in dflowfm.readHis (line 41)
hisdata.cross_section_discharge_int = nc_varget(filename, 'cross_section_cumulative_discharge');
I tried with several different map-output files from different runs and projects and always get the same error. Is this due to the newer version of Matlab or am i missing something? Those files definitely contain data, as they can be opened using quickplot.
Any help or advice on what to try would be appreciated,
Thank you,
Karoline
ncfile = 'map.nc';
returns the error
Thank you,
Karoline
Erik de Rooij, modified 8 Years ago.
RE: OpenEarthTools in Matlab v. 2017
Youngling Posts: 21 Join Date: 12/22/20 Recent Posts
Hello everyone!
I have the some problem. Could anyone help us, please?
Bruno.
Bruno.
Bob Smits, modified 8 Years ago.
Hi!
Anyone knows why I am getting this kind of error on my mesh?
Please, Look at the figures.
As you can see, I tried a simple rectangle and the same kind of thing.
Bruno.
Bruno.
