How to import Grid(D-Flow FM) into Delft 3D-Flow - Forum - Delft3D Flexible Mesh
- 5. Pre & Post processing
- 1. RGFGRID
- How to import Grid(D-Flow FM) into Delft 3D-Flow
Youngling Post: 1 Join Date: 3/30/15 Recent PostsDelft3D-Flow –flow input-domain-open grid command, only .grd file (grid(RGFGRID)) could be imported. Then how to import the flexible mesh into Delft3D-Flow?
RE: How to import Grid(D-Flow FM) into Delft 3D-Flow
Youngling Posts: 16 Join Date: 1/7/11 Recent PostsIn RGFGRID you can switch between structured and unstructured grids via "Operations" and then "Convert grid", for which there are two options: "Regular to irregular" or ""Irregular to regular". When saving a grid (i.e. exporting) you can only save a structured grid in "Grid(RGFGRID)" and an unstructured grid in "Grid(D-Flow FM)" format. An unstructured grid cannot be saved in the structured format "Grid(RGFGRID)".
With kind regards,
Erik de Goede
Deltares
Youngling Posts: 21 Join Date: 12/22/20 Recent PostsHi Erik.
The option "Convert Grid -> Irregular to regular" doesn't make effect. Do I have to do something before with my grid?
Youngling Posts: 16 Join Date: 1/7/11 Recent PostsDear Mahatma,
When converting a grid from irregular to regular (or vice versa) only the colour of the grid changes. It changes from dark blue (structured grid) to light blue (unstructured grid). Also at the corner point the nodes become visible in case of an unstructurerd grid. The grid itself doesn't change, which might suggest that nothing has happened, which is not true. The status has changed to another 'mode' and other commands have become active; see the commands in grey (inactive) and black (active).
With kind regards,
Erik de Goede, Deltares
Youngling Post: 1 Join Date: 10/23/18 Recent PostsHello. I have this problem too. I switch irregular grid into regular grid but lots of area of my unstructured grid removed. How can I use this full unstructured grid in Delft3D-Flow when input file has no _net.nc ?
Thanks for answering to my question.
